Need help connecting HKS SLD type I in auto ECU 1jz
I am having problems passing 120Mph, I want to go faster, my 03 civic Si was faster, anyway I bought HKS SLD type I because my car is a manual 1992 SC300 with a 1jz, but for my surprise when I was going to do the wiring on the ECU and is auto, and the pin out was different from manual ECU. So I am stuck now, but some how probably I can make it work just need some input or help finding the correct wiring if is possible or someone did it before, for what i research probably ECU is from a chaser, check pics below please I want to connect it the right way so don't fry my ECU.
ECU pics.
ECU plugs.
On this plug I think this the speed wire can some one confirm this?
HKS SLD according to the manual for 1jz all the set up buttons should be up, the manual is on Japanese so is hard to understand it. Any one know how the set up should be?
I found this auto ECU pin auto is this correct one for my ECU or they vary by the year of car or motor?
ECU pics.
ECU plugs.
http://img322.imageshack.us/img322/3503/jzz309gp.jpg
http://soarercentral.com/sc-forum/me...out2-45961.unk
pretty similar for all years in terms of ECU pins. Look for pin SP1 or SP2 and check to see if it's the speed sensor from the sensor side.
StiCk3
1997 Lexus SC
Trader Score: (0)
StiCk3's Avatar
Send a message via AIM to StiCk3
__________________
1997 SC300 5-spd, 1JZGTE 75% completed, 18x8.5 Niche Rhines, 245/40s all round, Xenon HIDs (6000k), '98 Supra Seats (tan), LS400 brakes, Fidanza 12 lb flywheel, Centerforce clutch, modified Apex'i GT Spec exhaust, FMIC, ARC BOV
1997 Lexus SC
Trader Score: (0)
StiCk3's Avatar
__________________
