Vinyl Pre-cut window trim Black out.
It wouldn't be worth it mate, get it done professionally. It's so much hassle doing it yourself and it will never fit right. You'll always end up with bubbles and there will be no warranty. You'll also find they post you the rear window trim in 3 sections, which will be visible to everyone.
(I'm speaking with 2 years experience as a car window tinter)
http://www.amazon.com/BLACK-OUT-TAPE...6148932&sr=8-1
use this to black it out yourself. if you have a razor blade and a steady hand it works pretty well.
Lets see,
Here's a thread from 2004 on the subject
https://www.clublexus.com/forums/sc-...tier-look.html
oh look... another one from 2006
https://www.clublexus.com/forums/sc-...e-chromed.html
No way...... another one from 2009?
https://www.clublexus.com/forums/sc-...rome-trim.html
there must be like ten threads on it already.
i just used this to cover up the black paint that covers up the silver window trim because it was chipping badly and it worked great. i had never worked with applying vinyl or anything and it went well. ill admit that i got a small bubble on each side but its barely noticeable and looks great considering my limited experience, so i recommend the job to just about anyone. its been holding up well it seems also.
good luck!
