SC- 1st Gen (1992-2000)
NEWBIE TO CLFL * 1JZ-GTE 733hp 591tq *
Old 10-07-10, 04:35 PM
  #76
evileagle
evileagle's Avatar
Originally Posted by //LRD
No head work, fully stock excepted for the BC 264's as far as internals. As for street ability, lets say the car has none from 1st thru 3rd.. However there are a set of solid dif mounts to help eliminate some wheel hop..
If you are considering doing a build like this , I say go for it . Boost is very addicting , so do it big and take your time to do it right..
Supporting mods, lots of fuel and of course a good tuner.. Two in tank Walbro 255's. and -8 to support them. A good stand alone is recommended this car is using a PSI EMS.. Another then that it's a great motor to start with.
Stock HG....thats nuts!
Old 10-07-10, 08:32 PM
  #77
//LRD
//LRD's Avatar
Here's the icing stock head bolts as well ..
Old 10-07-10, 10:24 PM
  #78
ASTERiSK
ASTERiSK's Avatar
You sure don't sound like a newbie, I'm guessing you mean you're new.
Old 10-08-10, 08:59 AM
  #79
99SC42
99SC42's Avatar
You SFL guys are taking the 1JZs to the next level, i have never thought you could make that kind of power on stock longblock and 264 cams lol.
Keep it up guys.
Old 10-17-10, 01:11 PM
  #80
plex
1UZFE/2JZGTE
plex's Avatar
How's the car holding up, heard through the grapevine a 1jz that recently made 7XX threw a rod.
Old 10-17-10, 08:27 PM
  #81
blk&blu*j
blk&blu*j's Avatar
Well let me bring this to light for the enquiring minds,
First the car was on a 21 lb map (boost setting A) the owner had put some 93 octane (3 gals) at towers to get out to Mexico and it appears that the car was starving for fuel due to the 2 in tank pumps (low fuel) and the inexperienced owner.
The car seems to have leaned out at the top of 4th gear in a pull, torched a piston and susequently created blow by and caused some oil to blow out thru covers and land on the exhaust header and turbo housing creating a small fire that was able to be extinguished by simply blowing on it.
There are no pieces all over a particular highway and if you close the hood no visual evidence of a fire the insulating mat on the underside of the hood is lightly burnt but didn't even fall from the hood, there are no rods protruding from the side of the motor and the oil pan is complete with no holes.
This failure is more related to driver error and lack of knowledge, than a failure from the actual workings of the engine or the management.
The car will return shortly and with a more vigilant owner (school of hard knocks$$$) is a great teacher!!
Old 10-17-10, 08:41 PM
  #82
plex
1UZFE/2JZGTE
plex's Avatar
^^^^ Dag sorry to hear about that. Is he going to stick with the 2.5 bottom or go with a 3.0?
Old 10-18-10, 06:03 PM
  #83
BAD954BOI
BAD954BOI's Avatar
WOW... that was a vivid story!!!
bravo roger bravo it was almost like i was there...
(but on the flip side sorry to hear about the car but some times you got to learn the hard way)
Old 10-18-10, 07:18 PM
  #84
Luv2xl
Luv2xl's Avatar
the ****....
Old 10-21-10, 02:37 AM
  #85
suprus
suprus's Avatar
What turbo manifold did you use by the way? And what were the measurements on the turbo? it was a BW s366 right? And i have some questions about the ems who can I contact for some info on it? Sorry for the questions but you got my attention lol
Old 10-21-10, 05:17 AM
  #86
blk&blu*j
blk&blu*j's Avatar
The manifold is a drewgo special, the turbo is a BW Airwerks s366 with a t-4 .88 open housing! Tial 44mm w/g at 1bar 2) 50mm Tial bov
Regarding the ems you need to contact Shaodome he is a CL member and has done quite a few CLFL members cars.
Hope this helps
FinalSC
29
03-09-10 03:33 PM
I8ABMR
02-01-10 01:11 PM
Wicked SC
Florida Lexus Club
32
04-02-09 12:08 PM
turbo6
75
04-09-07 03:21 PM
cliffud
22
01-18-06 07:04 PM
Quick Reply: NEWBIE TO CLFL * 1JZ-GTE 733hp 591tq *
