Still putting more stress on the studs than what they are made for.
Only option I could see with these is taking them to a machine shop, having new holes drilled with lug seats to put on the stock studs and putting new studs, but for the cost, might as well buy a GOOD set of spacers.
If you are running hub-centric spacers with wheels that are hub-centric to the spacers (or properly ringed), then the only significant stress on the stud will be axial, and the length of the stud does not increase (or decrease) axial stress. However, since those are not hub-centric, then you are adding shear stress to any studs you use because you cannot center the wheel on a hub. So, as he stated, they are unsafe regardless.
