Cooling
Cooling
Does anyone have experience with a high performance radiator and electric fans on the SC400? Any recommendations? Is it worth it?
Also, I am just about to order a TC and might add an aux tranny cooler at the same time. Again, any recommendations?
Thanks
Thanks
Range
Unless your engine water jacket cooling system goes outside the control range of the thermostat you don't have need for a more efficient radiator, it will do you no good whatsoever!
And a really simple way to raise your radiator efficiency is to get a 10-15F higher thermostat along with a higher pressure sealing cap. Improves gas mileage substantially also.
