Need advice for new bushings
My sc400 needs new bushings.
what are some good name brand bushings or i heard somehting about converting to some kind of discs. Please let me help if you can.
Been covered many many times buddy. Need a little more research... Research SC300/400 specifically and you'll get tons of result.
Daizen busing is one. You can get a set from TM engineering.
http://www.tmengineering.net/suspens...zen/index.html
Welcome aboard!
Welcome aboard!
Daizen isn't a "rip off" of Prothane. I suspect Daizen had some sort of contract with Prothane to manufacture the parts under that name which expired a couple years ago. TM Engineering had something to do with this, probably the R&D / test fitting.
Daizen and Prothane kits appear to be the same, except Daizen has a couple versions of the kit that include the inner and outer sleeves if the old ones are seized. I made my own inner sleeves.
Look on the Daizen site at the bottom for their versions.
http://www.daizensporttuning.com/pro...-bushings.html
The Prothane part number was mentioned by msc300
try mvpmotorsports.com
they have R2 Racing Control Arm Bushing Kits for the mkiv they work for all on the sc300 but for one bushing which you can grab if you tell em the diameter you need for the missing one
