SC- 1st Gen (1992-2000)
Help with swaping door lock assembly
Old 10-05-10, 11:04 AM
TakiSlice
TakiSlice's Avatar
Default Help with swaping door lock assembly
Someone recently back into my driver side door and totaled the door, I bought another door but need a DIY on how to change the door locks from the old door to the new one.
Thanks
Old 10-05-10, 11:12 AM
MIKU*SC3
MIKU*SC3's Avatar
Its not that all that hard to get to them.
Look up a DIY on how to remove the door panel first, or you can just look for the bolts.
I think three on far left of the door by the hinge, then 4 or 5 on the bottom of the door, and you hard ones are the two under the arm rest. And you gotta have a flathead to remove the black shield thats covering the last bolt behind the handle.
You should be able to do it by then, good luck with the door lock cable.
Old 10-05-10, 11:29 AM
MIKU*SC3
MIKU*SC3's Avatar
Or go to this link, it should help.
http://soarercentral.com/sc-forum/me...739/53268.html
Old 10-05-10, 12:57 PM
TakiSlice
TakiSlice's Avatar
sorry I guess I didn't explain it right, I need to swap the key lock on the out side of the door to another door.
Old 10-05-10, 01:05 PM
MIKU*SC3
MIKU*SC3's Avatar
OHhhhh, lol
My bad mang idk about that one.
Old 10-05-10, 04:40 PM
Mike552
Mike552's Avatar
you still have to do it from the inside , dont you?
Old 10-05-10, 06:15 PM
BenStoked
BenStoked's Avatar
yeah. iirc. once the door panel is off, there is a screw (or bolt) holding it into the handle.
Old 10-05-10, 09:01 PM
TroySC300
TroySC300's Avatar
This should help
https://www.clublexus.com/forums/sc-...-actuator.html
Old 10-05-10, 09:33 PM
TakiSlice
TakiSlice's Avatar
Originally Posted by TroySC300
oh yeah thank you so much, and thanks to everyone for there input.
BrendanS
05-29-18 07:07 AM
Lubeboy
05-30-17 12:52 AM
frknlolex
02-12-17 08:49 AM
Justinizme
01-19-12 07:54 PM
Quick Reply: Help with swaping door lock assembly
