Help with dash removal.
I'm removing the dash to paint it, I removed lower dash driver's and passenger's side (including glovebox, and center console). I don't know how to remove upper dash. I've searched and found one DIY but it's for old ones, mine is 97 and I don't have those bolts as shown in the pics. Can anybody help me with 97+ upper dash removal?
The DIY should work. I've removed a dash from a 92 and a 99 using that guide. Also, I put a 95 dash into my 99 so that leads me to assume the dashes are the same. Only difference would be whether or not you have a passenger airbag and if the wood trim is one piece or segmented
Which bolts in particular are you saying you don't have?
the top part of the dash has a wiring harness that u have to loosen/remove before u can even remove the dash itself. the harness is held in place by some clips and ancient pink factory tape that u will need to cut(and i recommend using zipties as the replacement when u put it back).
i did this 1 time when i removed my dash to paint it with SEM, and never again will i remove that dash, lol. its pretty easy, just a PITA.
Lol I really should think twice, do I REALLY want to take it apart lol but I already started painting with SEM lower dash, so if I started, I need to finish it. Btw, how many cans of paint did you use? It feels like I need much more of it than I thought...
i did my upper/lower dash, 2 front door pannels, rear side pannels, upper front/rear window trims, and both a-pillars with 3 cans of Landau Black. It looks factory..no one even believes its painted when they look at it. I did this last Dec and it still looks new today. I spent a lot of time prepping every surface, which is vital.
go for it, I felt the same way when you sent me that link about the ipod hookup. remove the cluster, two 10mm bolts holding dash behind cluster. remove airbag, first glove box, about 4 or 5 12mm for the air bag, L&R pilars have black plastic tabs. pillar trimand handle must be removed. drop steering column, two 14mm bolts at the base half way down the column. remove harness clips as you are able to see them. harness is also screwed in the center under dash- must be removed. dash snaps out, of course this is with ctr console removed.
the only thing different with yours is the position of the airbag bolts, use a flash light. any nuts you see need to be removed.
Here's the link to my thread https://www.clublexus.com/forums/sc-...te-2-pics.html
But there's not really much help in it lol, just inspiration for completion perhaps?
Good luck! It's not that bad
dont chicken out now man! just get it over with. u'll be glad you did it in the end.
Disclaimer: i am not responsible if you dont know how to paint! lol
Prep: i scrubbed all the vinyl panels with dish soap/water using a semi-rough sponge...then let it air dry. then rubbed the vinyl with a little Acetone/mineral spirit to remove any oil/grime...let it air dry. then wiped panels down with Clorox Wipes...dried with micro fiber rag and made sure there was no kind of lint anywhere....then proceeded to paint.
