NOOb question ?? Supra Tanabes on a sc 300...
Anyone know if the ride will have less bounce if I switch it to a firmer setting. I was told not to use the firm setting until the springs settle...
A rep at a Tanabe told me to drive on them for a while to break them in before changing the settings on the shock to firm... I dont know any better thats why I called to find out how to set them up...
and thats great news if the bounce decreases with a higher dampening...
Thanks
Thanks
Also when you adjust your dampers, turn **** 2-3 clicks at a time. Many times than not, a single click is not nearly noticeable, or will do nothing at all. Once you get close to the ride you want, make fine (1 click) adjustments to if it helps at all.
Thank you sir, I had no idea how to adjust these things... ILOVECOILOVERS!!! (one word)
I feel better I got the pro 210s...
![](http://i52.tinypic.com/x4j893.jpg)
Even if that was the case, driving your car down the road for 5 miles should have worn in the seals already. The only reason I could think of is that they didn't perform a shock dyno before the coils left the factory, which is something all manufacturer should do.
If you get the coilovers... just get some Pro210 springs. Get softer spring rate if you must.
http://www.tanabe-usa.com/pro210.asp?id=10
Meanshyguy
Suspension and Brakes
09-06-10 08:19 PM
supercoupes
13
08-22-10 12:19 PM
