Code 71: EGR...please help
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Ive got a code 71: EGR gas temperature signal.
EGR system gas temperature signal too low (below 149F for at least 90 seconds). Check EGR valve, hoses, etc; EGR gas temperature sensor or curcuit; vacuum switching valve for the EGR circuit; ECU.
Anyone with suggestions? I looked up some old posts and saw something about a block off plates and resistors. Anyone with further info? Any negative effects? Positive?
And one more important thing...where exactly is the EGR stuff???
Thanks!
Thanks!
http://www.mkiv.com/mohd/parts/egr_mods/index.html
you should be able to tell from the pics there where the egr is left side of the engine (drivers side) modulator is the thing will about 8 tubes coming out from it. seen in the pics at mkiv.com
hope that help
Yup, that's it. And the EGR Valve is underneath all those black tubes. My auto teacher suggested that I connect a long tube to the EGR valve and suck on it to create a vacuum to see if it's working. I'm not sure I want to do that...heh...we'll see.
And he suggested against removing the EGR valve, so I don't know what to do now...oh well...
zaruss918
05-12-16 11:33 AM
mpm86
GS - 1st Gen (1993-1997)
04-05-14 09:56 PM
