95 SC4 tail lights to 94 tail lights
I made the swap to the 94 tail lights and now my dash light is on indicating that I have a blown bolb. The connectors fit like a glove is there anything I can do to get that indicator light off.
I'm pretty sure you need to replace the tail light module in the trunk. Its a yellow module near the power antenna. You need to swap that with a 92-94 module and take out your 95-96 tail light module. The 92-94, 95-96 and 97+ tail lights all run at different OHMs so that is why you are getting the bulb out warning light on the dash. The correct module should correct this.
