SC- 1st Gen (1992-2000)
How to remove IACV??
Old 11-04-10 | 09:08 PM
1slowsc's Avatar
1slowsc
Default How to remove IACV??
i removed the TB and removed the top part of the sensor with 2 screws. i also removed the 4 screws holding the metal clip on the TB, i thought the sensor would slid out from here but i cant seem to get it out. What is my next step to remove it? my car is a 93 sc300 5speed.
http://i213.photobucket.com/albums/c...x/IMG_0278.jpg
http://i213.photobucket.com/albums/c...x/IMG_0279.jpg
Old 11-05-10 | 09:28 AM
1slowsc's Avatar
1slowsc
Can anybody shed some light on this? I tried searching but can't seem to find anyone with this problem. I don want to force anythng out. I need to clean my iacv.
Old 11-05-10 | 10:47 AM
good2go's Avatar
good2go
Am I looking at this wrong, or is that your tps that you've taken apart in the first pic?
I know I've seen a good write up on the IACV before. I'll see if I can find it.
Old 11-05-10 | 11:52 AM
good2go's Avatar
good2go
Here's some reference material for you:
https://www.clublexus.com/forums/per...rol-valve.html
http://www.planetsoarer.com/IAC/iac.htm
https://www.clublexus.com/forums/per...ml#post5493702
BTW, when you remove the screws for the IACV, Do it on a bench (not on the car) and be sure to use a really good quality and properly sized screw driver, as the screw heads strip VERY easily. Some people just outright replace the screws with an allen head type.
Old 11-07-10 | 08:59 AM
1slowsc's Avatar
1slowsc
Still need help, in those pictures it looks like it comes out in 1 peice. I want to clean it good, im going to be taking it apart again but need to get pass that step.
Old 11-07-10 | 09:31 AM
imDementeD's Avatar
imDementeD
yea you're removing the wrong piece in the pics..the iacv is the one with 2 screws holding it in on the left of the pic.
Old 11-07-10 | 11:49 AM
1slowsc's Avatar
1slowsc
Lol thanks I'll try to take the tb apart again.
Old 11-07-10 | 11:58 AM
imDementeD's Avatar
imDementeD
yea becareful i just did this the other day because of this thread..i didnt look at ur pics and thought you would of gotten it by now but anyway..
the screws are a PITA!!!! and i definitely stripped the bottom one beyond recognition ...i ended up having to use a pair of vice grips clamped onto the out side of it and oddly enough it loosened with hardly any force...
Ce3kay
01-10-15 09:20 PM
ronfsp
Automotive Care & Detailing
02-19-13 05:59 AM
ekrebs
Performance & Maintenance
15
11-20-08 10:30 PM
martialart
10-21-03 07:21 AM
