what camber kits are good for the sc to add more negative camber?
I'm looking to add more negative camber to my sc which ones should I be looking for?
why would you want that lol....trust me I have negative camber naturally and hate it. Tires wear out quicker and less traction in wet weather. Just get spacer and roll your fenders looks much better.
Last edited by DaveGS4; 11-13-10 at 01:53 PM. Reason: watch you language potty mouth
All I know is the lower you go, the more neg camber you get. Yes, you toe will def get mess up and get alignment otherwise your tires will wore out like less than 3 months. I never heard of a kit that will give you more neg camber, but I know there are kits that will correct your camber (less neg).
From what i understand the SC can get up to +/-3 with stock adjustment.Lowering would mean more is avail from there.
haven't Got mine running/on the rack at work yet but I don't need to much.Got some posi camber up front after LCA install etc.
Toe will Wear out your Tires...you can make camber work out fine.My Nissan has like -3.5 in the rear and Tires are Fine.
If you want more negative camber, I have rear upper controls arms with the camber correction kit installed backwards for more camber. The other route to go is to buy adjustable control arms for $700 per arm set, and a lengthy wait.
Let me know if you are trying to do it immediately, and more cost-effectively. I'll sell my arms for your legs
