18x10 +22 tire fitment?
If it's not what he wants to do then it is what it is. He said he doesn't want to run negative camber and he wants more fitting tires.
You aren't going to see camber wear from ~2 degrees of camber, though. So don't be afraid of some camber. It's beneficial. You'll have to go less aggressive on the offset to get more tire in there.
then just use the +40 wheels. you won't be able to use anything wider than 225, maybe 235, with 0* camber on your +22 wheels.
fyi, camber doesn't wear out tires as much as toe does, most people run through tires b/c they run too much camber, throwing their toe completely out of whack and not doing the proper mods to correct that, hence why they start seeing wires after 5k miles.
The front rims are 18x9's and I am wanting the stretched tire look on the front, not to extreme tho because St. Louis roads blow, so I need some rim protection. Any suggestions? I was thinking along the lines of a 225/35 on the front. The rear tire will be a 285/30
What do you guys think?
Dan@FSM
GS - 1st Gen (1993-1997)
07-23-08 09:03 AM
multitrack
12-06-06 03:45 PM
jpvarghese
SC- 1st Gen (1992-2000)
08-04-05 01:44 AM
