18x10 +22 tire fitment?
I tryed searching the forum and was unable to get an answer to my question. Will a (1st choise) 285/30 or atleast a 275/35 fit in the rear of my SC3 with rolled fenders? If not whats the widest I can fit?
my rear rims are 18x10 +22, my other off set option is +40 would that be any better?
Thank You
Scott
Thank You
Scott
22 offset with 18x10s, thats a perfect near aggressive fitment, i have 9.5 with 23 offset and the wheels fit the fender perfectly, but thats with 245/45/18s and negative camber,
with 10inches and 22 offset youll need a slight pull or flare to get the 275s to fit
honestly id do it i had alot of fun fitting a -44 offset 10" wide wheel on a 87 200sx
Does any 1 have pics of there cars w these offsets?
it won't poke too much, unless you're running like -0.5* camber, and if you are, gl fitting 275's. I had 255/40 michelin pilots on with about -2* camber, and had to raise my car way up to get it to stop rubbing around corners, and my rears are shaved.
![](https://lh6.ggpht.com/__rIDSYxpGjs/TJZ9_318imI/AAAAAAAABz0/r5vuWoCWkcE/s800/P1010129.JPG)
only pic i have.
only pic i have.
