SC- 1st Gen (1992-2000)
sc400 cuts out under acceleration
Old 11-19-10, 09:18 AM
sc4lover
sc4lover's Avatar
Originally Posted by bobob729
ya that is exactly what mine feels like is the fuel is cutting out for a split second....i am still searching for the problem but i have yet to figure it out. The drivers side coil wasnt the problem at all so im still searching for a cause to it.........im changing fuel filter tommrowo and i am also going to hard wire the fuel pump for a minute and see what happens
Tryed all of those..
Old 11-19-10, 09:59 PM
hovsc400
hovsc400's Avatar
im in the same boat as you guys i have read hours on top of hours to see wht is causing this issue it seems many people have this problem and its not even in the common issues list,,,but i to have not found a solution planning to mess with the tps keep the update rolling guys
Old 11-20-10, 02:36 AM
AerialAce
AerialAce's Avatar
Its crazy how old these things are and how common the problem is, yet no one has figured out this issues that supposedly so common its bound to happen =(.
I really hope someone gets to the bottom of this so we can get back to enjoying our cars.
Old 11-20-10, 06:56 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Mine started a little hesistation around 4k - 6k a few days ago, but nothing at idle. I wonder if its the same issue or problem that no one seems to know about how to fix?
Old 11-21-10, 12:52 PM
sc4lover
sc4lover's Avatar
Have any body changed there fuel pump
Old 11-23-10, 12:01 AM
AerialAce
AerialAce's Avatar
Never heard to anyone changing that, most likely because of where its located. I doubt its that though, my exhaust sometimes smells like its burning more fuel not restricting it.
Old 11-26-10, 11:33 AM
Meanshyguy
Meanshyguy's Avatar
My guess is o2 sensors
Old 04-20-11, 11:28 AM
BobbyB
BobbyB's Avatar
Default cutting out
Anyone every solve this problem...was it fuel filter or something else..?
Old 04-25-11, 01:04 AM
AerialAce
AerialAce's Avatar
Changing the cats (which where about 40-60% clogged) and the front 02 senors decrease the hesitation significantly, but its still there just not as noticeable.
Seems to happen when the car is cold, if I let my car warm up for about 10 minutes it runs perfect. I also found this thread, here. Going to get the rest of my 02's done, change the MAF, wires (spark plugs) and fuel filter when I change my oil soon. If all else fails I'll try the ECU, but I dough its that.
Old 05-05-11, 11:03 AM
MuGGzyx
MuGGzyx's Avatar
Just wanted to add to the thread so if someone else has this issue and does a search they might have better odds than some of us have had.
93 SC400
I did most of the stuff listed in this thread...
https://www.clublexus.com/forums/sc-...on-issues.html
Fresh plugs and cables, pulled them to make sure none were fouled, all were dry
New fuel filter
Unplugged the MAF and issue didn't change, didn't have a meter so I couldn't do that part but no change between MAF connected and MAF unplugged.
Jumpered the fuel ECU, could hear fuel pump whirring away so it's good, no change.
Bought a new coil, tried driving it with new coil in each spot, no change
Replaced Engine Coolant Temp sensor
Cleaned AICV
Adjusted TPS with Meter
Replaced Caps/Rotors
No vacuum leaks
All I can even think of at this point is the "Brain" that controls all of this other stuff.
Old 05-05-11, 05:59 PM
themisfit
themisfit's Avatar
i have a quick question what does itmean when my overdrive lite flashes on and off while i am driving
zeus87gn
Performance & Maintenance
02-14-15 11:03 AM
oaksc400
12-30-14 03:56 PM
SW2UZ
04-14-14 02:29 PM
NiceSC400
05-14-13 08:17 PM
Oconee1985
04-26-13 05:44 PM
Quick Reply: sc400 cuts out under acceleration
