so trying to put in rsx seats, removed the stock seats now what?
Alright i got some rsx seats i've been trying to put in for a little while,
![](http://i360.photobucket.com/albums/oo41/chnkylao/1289768994881.jpg)
![](http://i360.photobucket.com/albums/oo41/chnkylao/1289769010329.jpg)
I know the mounting holes in the rsx are different from the sc and i would like to use the stock mounting holes.
Alright the rsx seat bracket is 18" inches from left to right like and 15 inches long, while the sc is same width and 14" long. So they do fit.
Now onto the idea, I want to weld the SC bracket end peices to the rsx seat rails and I need some ideas on doing this. Here is the bottom of the rsx seat.
![](http://i360.photobucket.com/albums/oo41/chnkylao/1289770470035.jpg)
The end bracket pieces seem to be held on by some welds and some kind of screw
With an angle grinder i've tried to cut through the welds on the red doted line and the other side
![](http://i360.photobucket.com/albums/oo41/chnkylao/1289771727690.jpg)
now to the screw thing,
![](http://i360.photobucket.com/albums/oo41/chnkylao/1289771718209-1.jpg)
how do i go about removing this? drill through it? I don't think I can remove it any other way.
The SC seats, same idea I want to remove the end back peices so I can reuse them.
![](http://i360.photobucket.com/albums/oo41/chnkylao/1289771703234.jpg)
Originally Posted by rsx seat brackets
l l-----18"-----l l
l l
l l
15"
l l
l l
l l-----18"-----l l
l l
l l
15"
l l
l l
l l-----18"-----l l
Originally Posted by SC seat brackets
l l-----18"-----l l
l l
l l
14"
l l
l l
l l-----18"-----l l
l l
l l
14"
l l
l l
l l-----18"-----l l
![](http://i360.photobucket.com/albums/oo41/chnkylao/1289771694567.jpg)
I did the same exact thing. Putting the stock mounting bracket on the rsx seat bracket. All you have to do is just grind the whole thing out. The red dotted line is where you cut and those screws that you circled will never come out. (I spent 2 hours trying with no luck in the end) Then you weld it on the rsx bracket and bolt it back on. It's time consuming but very easy to do. Good Luck.
I did the same exact thing. Putting the stock mounting bracket on the rsx seat bracket. All you have to do is just grind the whole thing out. The red dotted line is where you cut and those screws that you circled will never come out. (I spent 2 hours trying with no luck in the end) Then you weld it on the rsx bracket and bolt it back on. It's time consuming but very easy to do. Good Luck. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
also the seats didnt come with the thing the seat belt buckle (i think thats whats its called), do you know if any honda one will work with the our seats belts?
EDIT or maybe i just need to fund a scew to screw the stock sc one in
seats in
![](http://i360.photobucket.com/albums/oo41/chnkylao/1290289462006.jpg)
![](http://i360.photobucket.com/albums/oo41/chnkylao/1290289492123.jpg)
first impressions, the stock sc seats are more comfortable, and alot lower,
My head is now an inch away from the top, sort of through me out of my comfort zone but ill get use to it
Its ok not jumping for joy in them, less body roll but for some reason i feel the road alot more now, idk they'll probably grow on me
