Sc300 2JZGE/Supra NA oil pan same part number?
i was just wondering if these are the same part numbers? i am almost certain they are because both are 2JZGE, but just making sure.
also does anyone have the p/n for it?
thank you guys so much.
MK4 (na) and Sc300 both share the same rear sump 2jzge. Not sure the part number though. I think the USA lexus and toyota part numbers are not the same. I will see what I can find at work.
The oil pan upper and lower are the same number.
You will need a pick up tube & gasket, oil dipstick guide seal as well as the "O" ring that goes where the upper pan and the eng block go together. (when doing the upper & lower)
The lower pan (93 Sc3/ 93 Supra) 2jzge #1210246031
The upper pan " " #1211146040
Pick up tube " " #1510446030
Try the Lexus vendors here.
*Are you converting a JDM market front sump motor over into a Sc3?
Aadaamm
SC400 / 300 Classifieds
11-28-10 03:24 PM
