timing belt replacement kit
I bought all of my timing belt/water pump/ cam seal etc. from Autohausaz.com... I listed below the autohausaz.com parts.
W0133-1627108 Air Filter $12.11 1 $12.11
W0133-1621914 Denso Cabin Air Filter; Activated Charcoal $39.67 1 $39.67
W0133-1642084 Nippon Reinz Engine Camshaft Seal $6.36 2 $12.72
W0133-1639695 Ishino Engine Coolant Outlet Gasket $5.78 1 $5.78
W0133-1644162 Kuzeh Engine Coolant Pipe O-Ring; For water bypass pipe $1.53 1 $1.53
W0133-1634310 Ishino Engine Coolant Thermostat $17.30 1 $17.30
W0133-1643194 Ishino Engine Coolant Thermostat Gasket $2.96 1 $2.96
W0133-1644030 Ishino Engine Coolant Water Inlet Gasket; For inlet housing $2.19 1 $2.19
W0133-1639016 NOK Engine Crankshaft Seal; Front $7.94 1 $7.94
W0133-1639543 Bosch Engine Oil Filter $3.61 1 $3.61
W0133-1608699 MBL Engine Timing Belt $54.20 1 $54.20
W0133-1619331 NTN Engine Timing Belt Tensioner; Hydraulic type $42.21 1 $42.21
W0133-1629901 Koyo Engine Timing Idler Bearing; Lower/left #2; Left Lower $23.71 1 $23.71
W0133-1622340 NSK Engine Timing Idler Bearing; Right $54.58 1 $54.58
W0133-1605400 Aisin Engine Water Pump; see epc note; w/ gasket $80.64 1 $80.64
W0133-1628940 Bando Serpentine Belt $23.32 1 $23.32
Parts Total: $384.47
Refundable Core Total: $0.00
Shipping & Handling: $0.00
