Stupid Question...
Stupid Question...
Where does the windshield wiper fluid reservoir go on a 95 JTZ SC 400?
I didn't have one so I got one online. It arrived and now I have no idea where the hell it goes. Do I have to take the fender off to put this thing in and is this something I can do myself or should I go to a body guy?
Thanks,
Nik
Thanks,
Nik
You have to remove the fender liner on that side at the front of the wheel and you have to turn the wheel but it would be easier if you remove the wheel. No need to remove the fender. It's a few bolts and I believe one or two plugs. It's really easy to remove or install.
Once you remove the liner, you will see exactly where everything lines up. The hole next to the battery tray is where the filler neck goes through.
marcoes300
03-16-11 05:25 PM
