problems while driving in the rain
I haven't had this problem before with this car. But today I had a hard time keeping the car straight on the wet roads. Every few seconds the steering wheel would jerk to one side or other.. The only thing that I had recently changed on the car was the struts and springs. Its pretty low all around. Could this be the cause the problem?
it alignment, tires and wide tires all plays in.... Mine my hydro anything over 50mph mostly cause wide, bad and probably reversed tires. I def got alignment, it help alot, before I would hydro at 35mph
The directional tires thing could be playing a part, too. My car handled like a scared cat in the rain with tires on backwards (won't be making that mistake again)
its your alignment. basically the rear. you have some toe now im sure from lowering the car. camber wont really do it but yes you have less traction from alot of camber. tires can play into also, width etc.... but its the same wheels and tires as before the drop. its your toe
