SC- 1st Gen (1992-2000)
A/C light blinking again after new compressor
Old 12-03-10, 09:59 AM
daweeze02
daweeze02's Avatar
Default A/C light blinking again after new compressor
So I got my compressor replaced about 4 months ago and everything has been working fine. Then about 4 days ago I noticed my air wasn't as cold...I used the thermometer and it checked out about 52 degrees. This morning the A/C light started to blink again, so I ran a diag like this and I got the double 00 so I am confused what my issue is.
ROUBLE SHOOTING
SELF-DIAGNOSTICS
An Electronic Control Unit (ECU) within A/C-heater control
panel monitors system circuits and stores trouble codes in memory if
problems are detected. All codes, except Codes 22 and 23, are stored
in memory. Malfunction is current if Code 22 or 23 is displayed. To
retrieve stored codes, see RETRIEVING CODES. Codes are displayed at
temperature display. See Fig. 2.
RETRIEVING CODES
1) Simultaneously press and hold AUTO and recirculated air
switches. See Fig. 2. Turn ignition on. All indicators will flash 4
times, at one-second intervals. Tone will sound when indicators flash.
2) A/C system will enter self-diagnostic mode. To end
indicator check, press and release OFF switch. Read codes at
3) If trouble code is displayed, proceed to appropriate
trouble shooting procedure. See DIAGNOSTIC CODE IDENTIFICATION table.
Codes are displayed in ascending order. To slow rate at which codes
are displayed, press fresh air button to change display to step
operation. Each time fresh air button is pressed, display changes by
one step.
4) If tone sounds as code is displayed, problem currently
exists. If tone does not sound as code is displayed, problem occurred
in past and does not presently exist.
Code Diagnosis
00 ................................................ Normal
11 (1) ............. In-Vehicle Temperature Sensor Circuit
12 (2) ................ Ambient Temperature Sensor Circuit
13 ................. Evaporator Temperature Sensor Circuit
14 .................... Coolant Temperature Sensor Circuit
21 (3) .............................. Solar Sensor Circuit
22 (4) .................... Compressor Lock Sensor Circuit
23 (4) ........................... Pressure Switch Circuit
31 .................. Air Mix Door Position Sensor Circuit
32 ................ Air Inlet Door Position Sensor Circuit
33 ............... Air Outlet Door Position Sensor Circuit
41 ....................... Air Mix Door Servomotor Circuit
42 ..................... Air Inlet Door Servomotor Circuit
43 .................... Air Outlet Door Servomotor Circuit
Old 12-03-10, 03:29 PM
tuterz
tuterz's Avatar
i have a new compressor and it does that sometimes too.. and i dont know why..
Old 12-03-10, 05:00 PM
daweeze02
daweeze02's Avatar
So it will not blow out cold air either? It's like the clutch engages for a few seconds then cuts off
Old 12-04-10, 03:00 AM
SChema
SChema's Avatar
You guys may have to have AC gauges put back on to see what the pressures are reading.
Old 12-04-10, 03:22 AM
CrazySC300
CrazySC300's Avatar
ROUBLE SHOOTING
SELF-DIAGNOSTICS
RETRIEVING CODES
one step.
Code Diagnosis
Wow! I didn't even know that you can do this with the SC's AC....Subscribed!
Old 12-04-10, 07:08 AM
sc3tech
sc3tech's Avatar
^ thats great info to have. thank you for that
Old 12-04-10, 10:53 AM
daweeze02
daweeze02's Avatar
I'm heading to Harbor Freight today to get some gaugues
Old 12-04-10, 10:54 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Sounds like a slow leak in the system from an improperly re-fitted linkage or fitting. Have the system coolant volume analyzed.
"R.T.F.M"
Old 12-04-10, 04:47 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
My AC blinks sometimes and barely any air will come out. If I turn it off and turn it back on, it's usually fine though.
Old 12-06-10, 08:44 AM
daweeze02
daweeze02's Avatar
Yea my old compressor used to do that but it eventually went out completely.....I am going to have someone look into after the new year
Old 12-06-10, 02:53 PM
antonio356
antonio356's Avatar
Check gas levels... Had it happen to my Soarer put gas in it and it didn't happen for almost a year after that... Put gas in it and see if it happen again..
Old 12-06-10, 04:53 PM
SChema
SChema's Avatar
Chances are if they replaced your compressor they would have added dye into the system while recharging. If you have access to a black light you can easily locate the leak, if any. Recharging freon is a somewhat precise process; too little, not enough pressure to kick on the compressor. Too much, keeps the compressor from kicking on. If you check your engine bay you'll see a sticker for the amount of freon, average car will take 1.5 to 2 pounds of freon from a state of vacuum.
Old 12-07-10, 06:38 AM
daweeze02
daweeze02's Avatar
I'm going to pick up this this weekend and check my levels
http://www.harborfreight.com/a-c-man...set-92649.html
I added some freon into the system about 2 months ago, I wonder if I need to pump air out of the compressor
Old 12-11-10, 04:39 PM
daweeze02
daweeze02's Avatar
Ugh I found out I was out of freon, guess a small leak. Anyways I started charging it and got it to about +19 on the gauge and the compressor kicked off. It seems like the low pressure switch keeps turning off my compressor. How in the hell can you charge a system when it keeps turning itself off grrrr
Old 12-11-10, 05:20 PM
daweeze02
daweeze02's Avatar
So I tried shorting out 2 pins on the low pressure switch to keep the compressor but maybe I did it wrong because it would never kick on, any help would be greatly appreciated.
Quick Reply: A/C light blinking again after new compressor
