need help can i bolt on Supra twin turbos on sc300
hey guys,
I have been looking but unable to find some info. I have a 1992 sc300 with a W58 tranny, i want to turbo it to become NA-T. And locally i found some good condition USDM supra turbos with manifold for cheap. I was wondering if i could just bold them on. I do understand i will need a BOV, FMIC and a downpipe recpectively. However, i read somewhere the supra twins will work with only the 2jz-gte ECU, is that case? Any help or info would be much appreciated. Thanks in advance.
thanks guys appreciate it. Yeah i'm going single then hah. first i'm doing all the maintenance, timing belt, spark plugs, water pump, new thermostat...etc. Change up my headgasket to a 2mm and boost time hah
Only the block, crank, and connecting rods are the same... other than the oil spray bars in the GTE block. So nope, they wont. sorry. I know MVP motorsports has a Boost Logic NA-T kit though..
