crazy overheating problem for great minds lol sc400 help
Ok. So my sc overheats probably once every 3 months. Usually it will be mysteriously out of coolant. But today its 17 degrees and it overheated I pulled over added like 2 cups of coolant then it stopped running hot.....but started running cold!!!! The temp gauge went slowly all the way to c. Now mind you I work 30 miles from home and this happened after I been driving 30 minutes. I drove for another 15 min and it kept dropping. I put a new failsafe thermostat in October. What can be wrong. Ps no leaks and coolant in exhaust.
If it's 17 degrees and you are running at any significant speed, you are getting an enormous amount of passive cooling right there just from the air passing through the radiator. It could be that with an open thermostat you are actually overcooling the engine. Semi trucks run covers over their enormous radiators in the winter to avoid over cooling.
Thanks everyone it was the fail safe thermostat. I de fail safed it and now its fine.....ish. Now its idling up and down like my integra used to do. Idle air problem. I may fix that today.
I had this happen to my sc. The return line that connects right next to the thermostat was rusted and plugged from rust and corrosion. The car would overheat once every three months randomly.
I would blow through the metal nipple and make sure that it is not blocked or corroded so that the coolant can flow freely through it.
