So i finally decided to upgrade my radio but i dont know what wire harness to get with it. Im going single din but it has two options of wiring harness "PFH-TO601" which says without factory amp and "70-8112" which says with factory amp. I do have the factory amp and want to run the factory amp. But this might sound stupid but which do i get or what do you recomend? What do you guys have? or should i get a aftermarket amp with new sub? Please help not sure what to do
Check out the audio and vidio section on this site. Tons of information on there about this. There are several possibilities about the question you are asking.
I've got a JVC double din touchscreen and I use it with my stock amp for the speakers. Get the harness that corresponds with your system which HAS the stock amp. Get the "with the stock amp" harness.
