Why put down the handling?
#31
the handling aint all that bad with just coilovers and decent tires in my opinion. No need for some crazy expensive German cars, Just get a Evo X or IX just as fast around the track plus its not $5000 for just a cat-back like the others
#32
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Remember while our suspension is similar to the supra's, Lexus gave the car much softer bushings and such, since the ride is supposed to be smooth as possible. Most SC owners want the luxury ride, not a harsh track suspension ride, so there's no huge demand for more performance or suspension parts for a Lexus SC, and only a small number of companies even make upgraded suspension parts for our cars.
That's all a bunch of what if's but i just cant rule out that the car has potential. without aftermarket parts. If the knowledge was there it might of been possible to order your SC like that maybe
This post probably makes no sense I'm just trying to look at it from a different perspective.
#33
It is not too hard to get good handling with the car:
At that point, add BBK's to front and rear too.
Ryan
- Install properly fit larger, wider wheels with lower profile tires.
- Install quality, adjustable coilovers
- Install Daizen bushings
- Install Daizen control arms, or Supra TT control Arms
- Install a quality front and rear STB
- Lower the car, but not too much
Ryan
#34
this has been helpful, learning what a lot of people have done to improve handling. I guess a lot of people find the Lexus SC300 to be a luxury cruiser more than a high performance touring car. Nothing wrong with that. I don't mind losing the comfort to have a performance car. There are ways to keep it simple and still keep it nice.
#35
after reading this my rear toe finally went on my car. it was swaying all over the road uncontrollably but i got it in the shop i will be ordering the following
Battle version traction rods
battle version rear toe arms
prothane rear uca bushings
i have the following in the front
coilovers(all 4 corners)
prothane kit for the front
tanabe (supra) sway bar
custom STB
old outter tie rods
is thier anything else i should replace while i am doing the rear or should i just replace the rear arms all togather
custom STB
old outter tie rods
#39
not bad for specs at all! I dont want to spend money on a Supra conversion when I can have control arms fabricated and poly bushings installed and have camber adjustment. There's a guy here in phoenix who builds porsche race cars and a few have some nicely fabbed components. I'm also looking into Ikeya formula arms, and im definitely getting the front lower roll center arms from ikeya formula and battle version toe and traction arms.
#40
#41
Yeah I mentioned this in an earlier post, changing the pickup points is the best way to lower a vehicle! I know Ikeya parts are expensive and I believe way over rated, but the are about the only company who offers a roll center adjuster arm for our car. thats the only arm im looking into getting from them
#42
OK here's my .02. Why not just get a 2nd car that performs as you want and leave the mods off the SC. I love my SC300 as a daily driver. It's comfortable can hold 4 people, drives on the hwy perfectly and looks good. Just what it was designed for. By the time you spend the $$$ to get the car to perform like some of the sport coupes - sedans , you've spent a ton of money and lost the essance of the car. Some cosmetics and maybe forced induction but that's about it. The car won't be the same after all the suspension changes and will have lost what I value the most.
#43
#45
Most people don't even know what handling good means. Often the case is for an average street driver, good tires, good allignment, will determine good handling or not. Whoever says the SC handles like crap is an idiot IMO and has never taken the car to its peak potential to know whether it handles good or not.
I track my SC, and i could tell you that the SC handles really well. Weather conditions, tire choice, and allignment again is the true determination to whether it will handle good at that moment.
I did about 40 laps around streets of willow Friday. I have 285/35 Hankook RS3's. First lap I spun out. I didn't blame the car, I blamed myself for not allowing the tires to heat up and taking a turn way too aggressively with a semi-wet frozen track. After the 5th lap, i didn't lose it one bit. I was able to come into turns alot faster, go through the bowl faster and more consistent, and take the shikane at 90+MPH.
If you're a hella flush kind of guy, with mad camber... The problem isn't the car, the problem is the choice of stance you chose. In the realm of performance, you will sacrifice comfort, and in the realm of comfort and stance, you will sacrifice performance.
One honest thing that the SC does lack is braking performance. I experience major braking issues when at the track with the stock brakes. They are unpredictable especially when late braking.
