Camber
I know products are limited, but does anyone have any experience gettting negative camber out of these cars? I have TCS sportine fronts and Im not getting anywhere near what I need. I wanted to see if anyone has any thoughts before I modify these or the factory arms.
I thought everyone said the TCS sportline fronts were death on wheels. If by fronts you mean the Supra front upper control arms. I think Diazen also makes a kit that replaces the camber bushing adjuster with something that has more adjustment.
Beyond that you are insane cause you are going into -8* + of camber. lolol
The threaded joint sections like to back out.
I know that my car stock is sitting at -6 so i imagine with daizen and the TCS's you could go way negative like well beyond the point of any kind of usefullness
I agree that is plenty for street use, but not for what I need to do. Ive had the arms on for 2 weeks and no problems. Im actually going to remove nut to get like 1 more degree.
