driving without a instrument cluster/climate control????
will the car work? haha
im thinking about sending in my cluster and climate control to lex tech but my car is my DD so i really dont have time.....
dumb question yes, dangerous maybe but i wanna know.
Keeper of the light
Just being helpful here, Xmas and New Years *may* cause delays. Since it's only 2 weeks I'd wait until the first to actually send it, regardless of when ordered if you are on a tight schedule. The current xmas sale / versus when you send it is not relevant to each other, but I think it would be helpful for me to at least suggest this.
^i used to live in Guam! Anderson AFB! thats a great little island!!!
but once its back in it will work.....right? haha if so im not concerned i dont plan on crashing
you will throw the airbag light if the key is turned while the cluster is disconnected.
which means when you reinstall your cluster the airbag light will be on and you must reset it.
to reset the light you have to under the hood to the diagnostic port and with 2 wire leads probe ports TC and AB. turn the key in the ignition switch to "on" but do not start the car. you will then alternate the leads from the diagnostic port on the negative battery terminal
https://www.clublexus.com/forums/sc-...ght-reset.html
http://mkiv.com/techarticles/airbag_light/airbag.htm
But YES, to answer your question..
GIMJ
SC- 1st Gen (1992-2000)
62
06-09-14 07:59 AM
100mgbluep
SC400 / 300 Classifieds
04-08-10 01:33 PM
