woodgrain?
woodgrain?
just wanted to know wht you guys do with your woodgrain, im not a fan of it and would like to paint it change it something...i know some guys have done something with the woodgrain just cant find the threads...would like to go with a piano black finish or similar or even like aluminum brush or something...
美少女戦士セーラームーン
I've seen a few people use carbon fiber vinyl to wrap around it and I've also seen someone with a black wood grain vinyl wrap once.
I found pictures of most of these in various member's build threads, but I don't have any links yet. I'll try to find a few a in later to help give you some ideas.
There was a guy who recently did a piano black finish and it looks amazing. I would suggest that or the black wood grain look.
If you're looking for another wood color, you can always try the 3M Dinoc series vinyl. I recently had this crazy idea to change my wood color to something unique. So I purchased a SC430 blond birds eye wheel. The rest of the wood was going to be sent off for dip tech but I found a 3M dinoc vinyl that was pretty close. The only issue was it had a matte surface. So I applied glossy vehicle wrap laminate that's able to curve and gives the impression of a clear coat. I have yet to install everything as I was sourcing the air bag and adapter wire. I finally got everything in and have been waiting for a warmer day to install. I got my inspiration from a white Soarer from Japan that's been posted from time to time that has the same light birds-eye interior. I'll see if I can dig up a picture for you.
EDIT: Found it!
EDIT: Found it!
