Whats The Easiest Swap??
I think the swap will be easier for you bro just ahead with the swap but not gonna happen with $2k if you replace the pump.seals.t belt and some other miscellaneous.
like I said there are couple ways to save the money on the wiring and use a gte aristo ecu if you do the wiring it will come out really cheap.I would have gone that route 3years ago if some had done it,and the 1jz stock ecu is some crap anyway.
There are both easy for me they both a day job.But for you I would think the 1jz with be the your best bet .
Keep us posted whatever you decide to do.
lol well i wanna build my NA block with a gte bottom end and delete my whole manifold and have a gte valve cover yeat also power but everything thats going into my car im doing myself i have all tools necessary.
im running the stock sc auto tranny but is a 5spd r154 swap that hard?
also keep in mind i need a new bumper door panels headlights etc..
why are you building the block? what's wrong with it?
are you aiming for 1000 hp if not I don't see the reason why you wanna build the GE bLock with gte parts .
lol you said you have $2k you can't all that with that kind.Maybe you have more money and you are telling us haha.
lol theres always more money to be made lol @quick but i might just go 1jz how hard is that on an auto tranny also what trannys can i use and think bout it 1jz plus bigger turbo = more easy power
Na-t
1jz
Na-t
1jz
redbarron
16
03-18-07 01:03 PM
