Christmas presents going on (gettin' flush!)
From: Sideways on the Yellow Brick Road! < Thats KS!
Like some of these? http://www.motorsport-tech.com/hub_rings.html
I'm not saying I have them, I'm kinda asking if these are the kind I should buy. And thanks
I also added a rotor pic so you can see the center hub I am talking about.
We all know what a hubcentric ring is for and what it does. 60.1 metal ones would be better. Was just sayin, I was shocked at the size of those things lol.
Post pics when you get em on I'm very curious to see!!
Some serious tire wear
I hate you
Finally got it off with a sawzall
Finding the rings for the car is easy. But you would need to have the rings made for these adapters. The center bore of these spacers could be anything 76mm 78mm 87mm who knows. Best thing to do is to make them lugcentric, by tightening the lugs in a crisscross pattern while supporting the weight of adapter off the factory hub (hand tighten first then impact to 85 lbs).. Make sure you use 60 degree tapered lug nuts.. Not the originals which are mag shank.. Good luck with your build..
http://cgi.ebay.com/ebaymotors/93-97...ht_3583wt_1165
it's either these or cut off the ball joint and have a heim joint in place of it. non replaceable ball joints can suck it.
lower control arms, sorry haha. but i searched and found some:
