Distributor at tdc
it should be pointing at the spot on the cap for cylinder #1.
Or you can line up the #1 cam pickup with the 1 tooth cam gear (should be same spot as above).
Or you can pull out the distributor and there is a notch you line up on the bottom gear (the part you stab into the engine) as well as on the base of the distributor. when you line the notches up that will also give you the position for TDC.
