Slot next to radio?
for those ppl who has installed optional cupholder, do you think it's necessary? I know $30-50 upgrade is not much but how`s the quality? looks to me cheap quality from those pictures. Is it useful? if it is, I`ll order next week.
Thanks for your input.
Originally posted by Lex Luthor
Clint, it's not Lexus' fault that when you hit 2nd gear your soda can gets launched into the back seat
- Jon
- Jon
ACleanSC4,
Have you though about putting up a "how to" in the ClubLexus forums? Sounds like you've got the info ready to go.
Overclocker
I filled that silly hole with a cellphone mount for my handsfree kit. ProKit makes a bracket that bolts up directly in that hole and leaves what ever you mount on it facing you on the right side of the dash. Best part is... I can still fit my wallet in the slot with my cell phone on the mount.
MW
MW
MW
MW
Originally posted by ChrisSC300
the cupholder is pretty worthless. It cant hold a full drink. Maybe an empty soda can, but thats it. BUT everyone who flip's it out is like "wooooow thats sooo cooool".
Quote "Do you have a link for this phone mount? I'd like to buy one!"
That is what it looks like.
http://home.pacbell.net/mwmail/incar1191.jpg
It is made by Profit and can be found at some mobile phone places.
Manufacturer website
http://www.pro-fit-intl.com/Default.htm
Place where I bought it
http://www.awswireless.com/store/lexus.html
Part # LX-53-92
I really like it...
MW
Part # LX-53-92
I really like it...
MW
Hey guys, here is the quick way to install the cupholder:
01-Press the Shift Lock Override button and pull down the stick into Neutral. Make sure your handbrake is pulled up.
02-Pull down the plastic piece at the bottom of your shifter and remove the 2 screws & pull off your shifter completely.
03-This is what it should look like.
04-Open the lid of your cup holder and with some force, jiggle it around and pull it out. There are two screws holding the trim down, so remove those.
05-Remove the entire piece around the shifter. It is held down by about 4 clips which pop right out.
06-After you pull it up, disconnect the 2 cables that are connected. There are 4 more screws that you need to remove in order to pull out the trim.
07-There are about 4 clips around the top and side of the trim that need to be popped out. Once they're all popped out, gently pull the entire piece out towards you.
08-Reach behind the empty slot and pop out 2 clips that release the piece shown.
