Just curious, are you experiencing heat problems with your amp mounted where it is? Because i am, and i'm in VA, i could only imagine how much hotter it is down in TX.
i dont have heat issues at all, but the amp has 2 internal fans. if you are having issues due to heat, you probably need a crossflow fan for air circulation/cooling http://www.amazon.com/Stinger-SGJ78-.../dp/B001HHSPYI
i know they're used and all, but if u don't mind, how much did u spend on the Abflugs? I almost bought a similar set last month from japan and just wanted to compare.
