hi guys... i have a 92 sc300.. i need to replace the wheel studs with longer ones. would you guys know if the is300 wheel studs is the same diameter but a bit longer??
If you need extended studs you can use the IS300 extended studs. I ordered a set of ARP extended studs off JEGS for the IS300 and it fits the sc300 perfect.
ARP 100-7715 is the part number for these studs, changed mine on all four corners.
Fronts go in easy, the rears can be a little tricky if you go the route without drilling a hole in the dust cover. I chose to do it without drilling and it took a little extra time.
thanks for the information.. i did the rears before and it wasn't that bad.. i was just trying to make sure that i get the right studs.. thanks everyone!!!!
^, Depends on how thick of a spacer you run; I would suggest extended studs for any spacers thicker than 5mm. At that point you should start looking at bolt-on spacers anyways.
