CD Changer and FM mod. install
Has anyone been able to get an aftermarket cd changer to work with the stock head unit of an sc400 car? I have a 1992 sc400 that need a new cd changer, is my only hope to go with FM mod.? Also any info on ho wto install the FM mod. changer?
To install an aftermarket changer. You run a plug from the control piece to your FM antenna feed in back of the factory stereo in the dash. Then run power, ground, and remote to the control base. The hard part is running the big cable from the control box to the trunk to plug into the changer. Lastly, you out the remote somewhere easy to see...and you are set...
If that is too much work for a cd player that sounds JUST LIKE your radio. Then you may want to find a new changer. They swap out fairly quickly. I have an extra if you need that route. PM me and I will shoot you a price.
MW
MW
40 minutes job
I bough a JVC cd changer and mounted in the trunk. The FM connect directly into my trunk's antenna. The problem is, you will loss all your digital sound. It was a bad idea to buy a FM CD changer
2GTSVETTE
01-06-07 07:28 PM
samerooo
10-31-06 10:52 AM
POLOLEX
04-02-02 11:09 AM
