Need help on removing fan pump!!
92 400 i took the bolt off the pulley and to find out the pulley itself has SEIZED and will not spin or anything... can some one please help me out on how to take the whole pump off...pics will help also THANKS!!
a pic would help i have removed my fan pump when doing the timing belt its a lil tricky to get it out be sure you disconnect all the hoses running to it and the big bolt at the top of the pump with the hydralic line running through it,,,and then there some other bolts in awkward spots and the pump should come right out.....do you know wht caused the pump to seize....
leak in the line and i didnt know so the gear got tooo hot..i just got a shorter belt and left the pulley and pump there...and just replaced the fan with a electric one
