SC- 1st Gen (1992-2000)
A few questions about LEDs
Old 01-10-11 | 12:09 PM
horent135's Avatar
horent135
Does anyone know the size bulb on the reverse light on the 97+ tails?
Old 01-10-11 | 10:09 PM
menty's Avatar
menty
Update: I have been emailing the supplier of the switchback LEDs, and it seems that if we run 1157 (3 connectors) bulbs in the corner lights, the switch backs will work. However, if they are 1156 (2 connectors), then they wont.
So what bulbs are used? Some sites say 1157, others 1156. Im confused
If you have an 1157 bulb, the 1157 bulb is a dual circuit bulb.
One circuit is usually connected to the parking light/headlight circuit and the other is connected to the turn signal circuit.
This is why there are three wires.
- Ground
+ Turn signal
+ Parking light
If it is an 1156 bulb, then there is no way to make it switch colors as there are only two wires going to the bulb socket:
- Ground
+ Power
There is no way to make this switch colors. All you can do is switch it on or off.
Old 01-10-11 | 11:36 PM
VinnyMac's Avatar
VinnyMac
I used 1157's on my '95 SC300 and that's what is stated on Sylvania's guide.
Old 01-11-11 | 12:11 AM
menty's Avatar
menty
Do they light up when you turn your parkers on?
Old 01-11-11 | 12:25 AM
VinnyMac's Avatar
VinnyMac
Negative. They only light when I turn the signals on.
They aren't parking lights. Parking lights are 194's which I exchanged for LEDs as well.
RudeDoggy
General Classifieds
07-10-13 07:06 AM
satz
12-24-12 07:08 AM
whytry
11-01-12 03:34 PM
thirdmotio
Lighting
22
07-28-05 10:29 PM
nosml
10-07-02 10:44 PM
