Stick with the TE37's. In my opinion both wheels scream too loud on different ends of the spectrum as to what the cars image is trying to pull. With that being said, all around the TE's look much better.
Yeah thats pretty much what I was thinking : D But the TE's arent TOO sporty, they're just right! And the BBS's are too much of something I dont particularly find tasteful. But you should pick the one that will take longer to bore you ; )
I don't think you should get lms because there are so many knockoffs out there there will be a few sc's with the same rims be original get somthing else.
Do what ever you want to do. I know that you lean towards one more than the other. It's impossible to be perfectly balanced between both rims since they're so different. The majority's vote shouldn't matter. Only thing that matters is what you will be happy with. Both wheels look good. It all depends on what type of look you want to go with.
