Climate Control or Radio?
Ok I bought a head unit from someone on here since the lights on my display didnt work.
However, being its a '98 I forgot I needed the green, not amber lights.
So I swapped it out and although Ive never had a problem with climate control, its seemed to start flaking on the temp side once i reinstalled it. Not sure why removing it for 15 mins caused a problem but apparently it did. But now the lighting color is mismatched.
my question(s) is would it be easier to just replace the CC with an amber lit one or easier/cheaper to change color on the head unit? to green.
...idk how hard it is to change the head unit..but i changed the amber lit ac control very easily by switching the bulb covers...the ones that came on the amber one where white..where the ones on the green ac control where blue..so i swapped them over and got green lit ac control...it may be that easy for the radio..something you can try if you feel confident enough to do so
trying to keep it stock for now.
