Wanna go HX35/40 single turbo on 1.5jz
I already told you what to do. Why are you asking again?
HX35 has a beefier shaft for the CHRA then the 40 series. So do the 35.
HX35 will go up to more horsepower then you can handle.
And what do you mean as far as gas...pump. That doesn't mean anything.
91 octane, 93 octane? 84 octane? That's what matters. The higher the number, the higher detonation resistance.
Eg. 93 octane @ 15lbs on a HX35. You can have up to 20-23 degrees timing before you detonate. 91 octane, only 15-18 degrees. Timing makes horsepower.
You can run 50lbs of boost on 91 octane, but your timing will only be 1-2 degrees. It's a pretty linear scale with boost vs. timing in regards to octane..
It's not the boost or timing that melts engines, its *Cylinder pressure. The combination of both.
You heard the term Cheap, Fast, Reliable, pick 2?
Compression, boost, timing. Pick two. But that's a whole other can of worms.
You will be fine with an HX35 bolted up, at 12 lbs or so. Everything can handle that horsepower level fine. (Inj, trans, ecu,etc)
Don't talk about it, be about it!
im ready for this swap, i just need to find the turbo itself (isnt to easy) i have places here in miami,FL that im waiting for quotes on for the work already so im about to be about it lol
as far as gas i use 93 always
I plan on boosting my HX35 to the mid to upper 20's. I only have 440 CC injectors so i think my end result should be about 450HP and 400TQ... should be fun and i will post a video as soon as its complete
Heres a pic of my setup
This is the bracing we mounted to the flEbay manifold. Drifting is probably gooiing to shake it a littel so i wanted to get the manifold Solid so i dont get stress cracks.
Here is mine and my buddys. He has a 2jzge with a Heor hy351 i cand remember
Triple C are you using a oil feed restrictor on the 1jz HX35? I've gotten mixed stories.. Some say you should and others say you are not suppose to. What's your verdict? Are you using a restrictor in the oil feed line and if so, what size?
No restrictor Planned at this time. I dont want to restrict the flow any. I want it to Flow as much as possible so it stays cooler. If the pressures are to high i might have to but i will face that demon soon
must the intake mani be upgraded too?
i hope all goes on the build looks sick, im gathereing parts for mines but i cant seem to find a hx35 here in miami... you any sites where i can get that turbo...
ayy.... i dont make the rules lol. tell me how i thought it was 93 everywhere till i got in this site lol. thanks for the help man
so i am guessing you used a t3 flanged manifold from ebay?
