Oil Feed to turbo on a 1.5JZ??
Don't run it from the big bolt that hold the oil filter housing in place, because the oil you picking up from there is not filter yet.
I ran mine from the oil pressure swith and moved the oil pressure switch at that bolt on the oil filter housing.
Dont ruin your union bolt, or waste time using the IS union bolt and blah blah blah...
Get one of these, install it in 5 minutes, and call it a day:
http://www.glowshiftdirect.com/Oil-F...-Adapters.aspx
I had one on my na-t, had ZERO issues. Very worth the price for something very simple to use and install, and gives 2 extra ports for oil temp and pressure gauges..
6SOARER
Performance & Maintenance
20
02-24-11 04:36 PM
