SC- 1st Gen (1992-2000)
spark plugs
Old 01-18-11, 09:00 PM
hovsc400
hovsc400's Avatar
Default spark plugs
in the mix of completing my full tune up on the 400 and trying to figure out this random misfire when accelerating as many ppl are having this issue based on the countless threads i have read with no resolution to the problem.....so after timing belt, distributor caps and rotor buttons,driver side coil, cleaned maf. wires with new spark plugs and trying 12v mod problem was still there...so i spent my day going through sensors, wires, vacuum lines etc, i noticed a maintenance sticker inside the hood that says PLATINUM plugs to be used which is not what i bought when i replaced them and it still cost me $4 bucks a plug...so made a phone call got a deal on some bosch platinum's $20 bucks for all 8, gapped them to .44 dropped them in an wow this car is finally driving so nice accelerates with no issues idles nice and has all its power back in all ranges of the rpm......so to my 400 drivers who may still be having hesitation issues when driving platinum plugs gapped to factory specs .44 makes a night and day difference.....
Old 01-18-11, 11:46 PM
boostin240
boostin240's Avatar
Do yourself a favor. NEVER RUN BOSCH plugs in Japanese cars. Your engine will love you for it. NGK OR DENSO ONLY !!!!!! SORRY just gotta hate on Bosch plugs. Never seen the reason behind them. Factory specs call for NGK / Denso usually.
BUT Yeah spark plug gap is very important.
Old 01-19-11, 12:08 AM
scENFORCER
scENFORCER's Avatar
I'm about to buy some NGK's (most likely) for my '99 SC4. What are they supposed to be gapped to? Same thing as non-vvti?
Old 01-19-11, 08:40 AM
roccadet
roccadet's Avatar
I was losing a lot of HP as well in my 95 SC 400. After replacing only 4 spark plugs I got a lot of it back. I bought them from Lexus for $10 each, probably paid a little extra but knowing that they are Toyota plugs is worth it.
Old 01-19-11, 01:39 PM
hovsc400
hovsc400's Avatar
.44 is factory spec gap
Old 01-19-11, 04:02 PM
BartleDoo
BartleDoo's Avatar
Jeez! Get the other four somewhere else because Toyota doesn't make spark plugs and you can get the same plugs for way cheaper. As for Bosch, I would have rather seen those when I pulled the spark plugs out of my SC for replacement than the Champions that the previous owner installed.
Old 01-30-11, 10:47 AM
tuterz
tuterz's Avatar
anyone have a DIY spark plug change.. i cant reach cylinder #3 and 4 .. gonna try to do a full tune up before putting my car up forsale.. oh a DIY for a sc300! .. not 400
Old 01-30-11, 10:54 AM
iridebmx
iridebmx's Avatar
take off your throttle body.... imo thats the worse place for a intake manifold ever! haha
Old 01-30-11, 11:18 AM
tuterz
tuterz's Avatar
anyone know how many bolts are on the throttle body? .. and yes.. that is the worst place ever!
Old 01-30-11, 11:27 AM
good2go
good2go's Avatar
Seriously??
7-1/2 years and 1000 posts!
Old 01-30-11, 11:29 AM
GSteg
GSteg's Avatar
I bought them from Lexus for $10 each, probably paid a little extra but knowing that they are $7 Denso plugs is worth it.
Edit for you
Old 01-30-11, 11:49 AM
brad11140
brad11140's Avatar
This is interesting. I just did the full tuneup and I installed NGK laser iridiums. Haveing the hesitation issue in lower RPM's. I have a TPS sensor on the way and this is after I have had everything else apart. IAC valve. EGR valve. Replaced ECT sensor. Have removed and carefully cleaned my MAF a couple times. Would suck if it is something as simple as plugs. Oh well wont hurt to have a new TPS sensor.
Old 01-30-11, 12:05 PM
scviolence
scviolence's Avatar
+100000 lol
Old 01-30-11, 12:12 PM
ishootstuf
ishootstuf's Avatar
Make sure if you are gapping platinum plugs - which you usually don't have to - that you do it right. Don't wedge stuff between the center electrode and the ground electrode.
Old 01-30-11, 12:42 PM
good2go
good2go's Avatar
This is absolutely mandatory for gapping Iridium plugs
Quick Reply: spark plugs
