SC- 1st Gen (1992-2000)
What is this warning light
Old 01-21-11, 10:41 PM
  #31
lk123
lk123's Avatar
I was thinking speed racer lol but no for realz whats it mean cuz mines on too
Old 01-21-11, 11:51 PM
  #32
Tret
Tret's Avatar
Originally Posted by lk123
not hijacking but whats the top right light that looks like the rear with spikes lol
Third Brake Light.
It had it one when I didn't have my plugged in while unclipping it to get to the sub!
Old 01-22-11, 12:01 AM
  #33
lk123
lk123's Avatar
im so tired i dont understand what u just said lol my 3rd brake light works and the dummie light is on
Old 01-22-11, 01:52 AM
  #34
scENFORCER
scENFORCER's Avatar
It's not 3rd break light specific. It's a tail light indicator, one of ur bulbs must be out. Look lsely though cuz I just had this and everything looked fine upon initial inspection. But when comparing it with the other side I could see that one was out..
  #35
Tret
Tret's Avatar
Hmm odd, I'll have to take a double look at if once I'm not dead tired as well. If anyone can stand correct let me know.
Old 01-22-11, 08:36 AM
  #36
lk123
lk123's Avatar
alright thanks, at first i thought it was a rear bumper smash censor or somthing from a wreck
Old 11-03-14, 03:03 PM
  #37
t2d2
t2d2's Avatar
Originally Posted by brad11140
BTW it did not come on when I removed the connector because you have to ground it. Helps to read all of the instructions. Sheesh Im going to bed.
I have a new coolant level sensor on order to replace mine. I took it out to see if the slow goopy leak was from the tank or the sensor. The tank appears to be fine, but the sensor had a long crack toward the bottom (and the float fell apart in my hand; wouldn't want chunks of that clogging the hoses) that looks like it's allowing coolant to work its way up the wires and seep out the openings at the top.
While waiting for the new sensor to arrive, I figured I should disconnect the old one to make sure I get the low coolant warning light, otherwise there's not much point swapping it out when I could just cap it. I didn't get the expected warning light... I found a few explanations that the warning light won't come on when the sensor is disconnected, but the above quote is the only one I found saying that it has to be grounded. I'm just confused what that means, exactly. The warning light won't come on unless grounded or the harness side of the sensor needs to be grounded to trip the warning light? I couldn't find anything covering it in the service manual.
robert187
18
04-09-11 11:48 PM
jdmtruong
Performance & Maintenance
19
03-30-06 07:07 AM
johnsonjam
12-04-05 02:32 AM
MatT3T4
03-22-03 11:15 AM
screwj
06-10-02 04:50 AM
Quick Reply: What is this warning light
