SC- 1st Gen (1992-2000)
battle version rear end installed
Old 01-21-11, 03:25 PM
t70 supra
t70 supra's Avatar
Default battle version rear end installed
just got my full battle version goodies installed also i just bought 4 NS-II nanking tires should i wait to get my alignment with new tires or just get them done with my old tires
old tires are fubared to hell and then some
to anyone going to do this own your own i reccomend pb blaster for 3 days to loosen all nuts and bolts the camber bolt the cam's will be the pita.
so i highly reccomend buying new 1's with cams before u start tearing anything down
complete
Old 01-21-11, 03:35 PM
QwkSC
QwkSC's Avatar
Anything Battle Version is a Win!
Rather than buying new tires, switch your left side with your right side tires. That way the outside is now the inside.
Old 01-21-11, 03:54 PM
t70 supra
t70 supra's Avatar
i did man i drove it the car is fucn amazing well worth the moeny and time now as soon as my new tires get here is on and cracking
Old 01-21-11, 04:00 PM
QwkSC
QwkSC's Avatar
Suspension is so often the most overlooked part of a cars performance. It's not just about the 1/4 mile.
Old 01-21-11, 04:38 PM
sayayin
sayayin's Avatar
where do you get them, how much they are and they have for the front? I was thinking ikeya but they are expensive
Old 01-21-11, 04:58 PM
TougeSC3
TougeSC3's Avatar
http://www.battleversion.com
Old 01-21-11, 05:23 PM
t70 supra
t70 supra's Avatar
i would get the ikeyas for the fron search lexant's car
Old 01-21-11, 09:37 PM
jadu
live.love.laugh.lexus
jadu's Avatar
good stuff!
Old 01-22-11, 06:17 AM
CSSC400STL
CSSC400STL's Avatar
I'm having the same problem with my tires I was just going to buy a camber kit to fix it
Old 01-22-11, 07:29 PM
justin1642
justin1642's Avatar
are the battle version links suppose to be able to get you back to factory camber, if you choose to?
good luck trying to get that, you might want to start looking at alternatives.
Old 01-22-11, 07:40 PM
t70 supra
t70 supra's Avatar
Yes but you should use the lance alignment specs
Old 01-22-11, 07:43 PM
justin1642
justin1642's Avatar
I haven't heard of those specs.
Old 01-22-11, 08:47 PM
t70 supra
t70 supra's Avatar
look them up on supra forums it helps give even tire wear and better handling
Old 01-24-11, 07:21 PM
BattleVer
BattleVer's Avatar
The easiest way to get your rear camber back to spec after you drop it is to just cut and reweld the lower rear arm (camber arm). I had to take a bunch out of mine. Sometimes its better to mod the stock parts then replace them with crappy or expencive stuff. Some arms are easier to replace then mod.
Old 01-24-11, 07:24 PM
chnk
chnk's Avatar
idk I dont like the idea of weld no matter how strong cracking and coming apart under stress,
Quick Reply: battle version rear end installed
