Need Help, car shaking after tps fell off.
Alright I had my 92 SC300's headgasket done 2 months ago and was driving it for a while, then all the sudden yesterday I was leaving a parking lot and the car just started shaking and lost like 30% power, so I drove it home and popped the hood and notice that the TPS is off. The **** mechanic I took it to to have the headgasket done must of only put in the bottom screw which loosened up and let the sensor fall out, well now I put it back in and it still runs like ****, no problem reving, no smoke, no fuel vapor, just shakes still. It's like when an ignition coil goes bad but without the fuel being unburned and coming out in white vapor.
Anyone have any ideas or suggestions?
are you sure you put it in correctly? most of the time you have to put the TPS in turned already... then once it is in place you turn it back straight up and down like normal... thats about all i can give you without seeing the motor or being there in person
When reinstalling the TPS, you have to check the Ohms and Volts, and set them back to manufacturer recommended specs as listed in the FSM.
You will have 2 different reading that need to conform to what the FSM has listed, one reading will be with throttle closed, the other will be WOT position.
Here you go attzor:
https://www.clublexus.com/forums/per...djustment.html
and to turbodreamz... yeah true... it was 1am and i wasnt all there when i typed the post however the TPS should have never been removed to begin with
It was the mechanic, I have never touched the TPS, he likely removed it in trouble shooting for why it had a miss fire. There was only 1 screw holding the TPS in, vibrations caused it to loosen and come off, not all the way, but to the point there it was able to be completely lifted off the throttle body. This was a VERY bad mechanic and I will never be returning, there is ALOT of bolts missing under the hood, the cruise control cable was just sitting next to its little spot, not even bolted up.
This was not a shop mechanic, it was a person who works with salvage lexus parts and cheap labor on lexuses. He didn't even do a compression test to confirm that it was a BHG, which it was not, it was a bad power steering solenoid, which I had to tell him to check because he couldn't figure it out.
Todd1225
Performance & Maintenance
16
08-15-09 09:12 PM
Todd1225
04-13-07 10:59 AM
