Puddle Light info and Pics Thread
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Is there a writeup on the Puddle Lights mod that are simple and easy to do? or its something a professional has to do Please share info/pics if you have done this mod any suggestions that will help make the project easier
thanks
Its pretty easy to do. Take off your side skirts and use a ruler to make sure they are all spaced out correctly. Drill the holes out and make sure its flush. I wired mine into the fuse that controls my interior lights when my door opens. They turn off when my door closes.
If you get them installed shouldnt be more than $60-80 bucks labor.
have got to bring this one back for some pics and any kind of help on doing this to the sc
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Here are some pics of when I had the puddle lights on my ride....
![](http://i40.tinypic.com/2comql3.jpg)
![](http://i39.tinypic.com/11gkm0k.jpg)
![](http://i41.tinypic.com/16ldx83.jpg)
If you follow eliteskill's steps that's basically what I did. I tapped into the light that's underneath the driver side and put the puddle lights on a metal rail painted flat black and then screwed the ends of the rail onto the side skirt.
In the future I will do this mod again when the car is not my DD and actually put the lights in the side skirt to make the lights more flush and unseen.
[QUOTE=P.R.S.22;6175080]Here are some pics of when I had the puddle lights on my ride....
skirt.
thanks for sharing the pics what kind of metal rail did you use? i might just do it the same way you did
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Thanks alot man and I forgot to tell you how great it looks on your sc well done sir. The second Pic you posted above under the metal rail what is that Picture showing a light or something?
A CL vendor on here sells the flat LED puddle light setup for a good price so I would check the vendor section first.
I think it will turn out great Klaus. I like the way the lights are separated in the Brabus. Like I said I would have to try again and see if puddle lights are good for DD over the long haul with a better LED source. From my experience so far they may be better off in a more car show like vehicle or a sunday driver not being used every day.
Sir...I know for a fact your car does not need it's puddles lit either....it's perfect just the way it is
Haha....I'm sure once your done with the new mods for the car Scott puddle lights will be the last thing on your mind ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I agree Klaus. The spacing is just about perfect in the Brabus with the end lights at the very end of the sideskirt. It seems 4 puddle lights are better than the 5 I originally had. If spaced out correctly the 4 lights should do the trick just right.
I think more and more high end car companies will be going towards putting puddle lights in their cars just for that particular reason.....they are certainly functional when you get out of the car and want to see what your stepping into in case it is dark outside and not alot of street lights around.
