SC 5 spd REV MATCH experts
To all the manual drivers out there, how do you guys rev-match?
I've been used to double clutching on my SC300 with pretty good success ->
I'm currently in 4th, I press the clutch down, put the gear into neutral, clutch up, blip the throttle, clutch down, gear into 3rd, slowly let the clutch back up.
That was double clutching. Now, my question is how do you guys rev-match? Here's what I think is how it's done and I've tried several time:
I'm currently in 4th, I press the clutch down, put the gear into neutral, with the clutch still down, I blip the throttle, gear into 3rd, slowly let the clutch back up.
Notice that the only difference is not bring the clutch up again & down (so no 2nd clutch and therefore not 'double' clutching).
Is this correct? Because I was told when I learned to drive stick that you should not have both clutch down and foot on the gas at the same time. That's considered riding your clutch.
Does it hurt my clutch when I have the clutch all the way down and blip the throttle? Please answer if you are an expoert!
For any given vehicle speed,there's a "matching" rpm,depending on what gear you're in.
So,if you are cruising along at 2500 rpm,and want to down shift,you do the double clutch thing you'd described,except you'd let the clutch back out(engaged) right when the rpm was right for the gear,speed;say 3400 rpm perhaps.
This allows for easier/faster/smoother shifting.
In alot of cars,you can drive without using the clutch,once you're off the line,just by matching the revs,and shifting at the right time.
SCV8, I realize that. So is the steps I described for blipping the throttle to REV matching correct? By not doing the 2nd clutch? if it works also, then what's the technical difference between that and double clutching? wouldnt it be better since it requires a step fewer and therefore faster?
I need to know if the 2nd step I described is harmful to the clutch.
why are you double clutching? are your synchros screwed up or something?
there's absolutely no point otherwise
rev-matching is easy; just blip the throttle up about 1200rpms per gear your going to downshift and slide it into gear and it'll go fine...
it takes fine tuning and practice to make a downshift that doesn't jerk the car
double clutching is something out of "the gay and the curious"
diesel semi-truck guys use it mostly
blipping the throttle just means you hit the gas to kick the rpms up... don't hold the gas, just tap it down enough where it kicks up 1200rpms and then shift...
see what i'm saying?
this leads you into the heel-to-toe braking brake with your toe and blip the throttle with your heal when you downshift going into a turn
arg. i'm going to pull my hair out.
i know that blipping the throttle is quickly tapping on the gas.
what my question is, what do you do w/ the left foot.
let's say u r in 3rd gear, and u want to downshift into 2nd.
please describe every step as I have w/ the 1st post.
ok, if you're in 3rd gear at about 3000rpms let's say you are not pressing any pedals and you are engine braking up to a turn
since you're at 3k rpms, you need to downshift into 2nd, which will require to have the rpms around 4200-4300 to keep it from jerking too much...
this is assuming you are not touching the brake at all;this is the simplest way...
this is what i do: push in the clutch, downshift to second, blip the throttle where it soars to around 4200rpms; then release the clutch
you can also blip the throttle before downshifting, but i'd do it the other way because of speed and time issues (rpms might fall too much)
after that if you matched the revs correctly, your engine will suddenly start slowing you down a lot more; and there will be little if no jerk to the car
Bean, thanks, that's exactly what i'm looking for. Also exactly what I've been doing.
SO the only difference between rev matching and double clutching is that extra clutch step in which I blip at neutral with clutch out rather than clutch in.
Anyways, I've also tried rev matching when I blipped with the clutch all the way down and the gear still in 3rd. That's okay too right? Since I'm in 3rd, I stepped the clutch all the way done, blip the throttle and shift to 2nd, then clutch out. Seem to work the same.
Double clutching felt a lil smoother when I shifted but more work and slower. just my thought.
yeah thats what i was saying... you can do it either way
if you blip as the last step though you give the motor less time to wind down
clutch in, downshift, blip throttle, clutch out
takes practice, but its worth it once you're done
double clutching is TOTALLY pointless from ANY performance standpoint... all its used for is for cars that have bad synchros or vehicles that have NO synchros
more crap from the FnF that was BS
scsexy
Performance & Maintenance
01-03-17 05:54 PM
