Need wire diagram and pinout schematic for Soarer harness
I need a wire diagram and pinout scheme for the SOARER harness. I seen a few on SupraMania for the 2JZ/MA70 but NO soarer. There was a few diagrams on Google but are all the 1JZ's wire diagram the same-Soarer/Chaser/Supra?
Are the 2JZ schematics similar to the 1JZ?
http://www.supras.nl/index.php?optio...d=34&Itemid=50
Did you try to start it again this morning? Just ground T1 to the body somewhere because E1 is just a ground so you can just ground the T1 and see if you get a cel..
Do you have a spare ECU? if you can find spare i would try ...it's 1jz ECU it can go bad without being use lol...
I am at work, Im gonna mess with it when I get home after I pick up some wire,solder and heatshrink cause I still need to extend the ECU harness.
The ECU plugs look intact, its just the body plugs that have a few wires disconnected and I wanted to know where they go. I grounded Te1 and e1 the other day and the CEL flashes continously. I'll ground Te1 later when I get a chance to see if I get any codes.
I still need to fix the oil and fuel leaks. I think the oil leak was coming from the custom feed line I had made. Fuel leak, not sure yet. Im Gonna get a better look at it today.
I was tryna get someone local to lend me their ECU so I can test it but no one has one or doesnt wanna help a brotha out .
I'll let you know how things go
