NEED HELP!! No power coming to the stereo.
I just bought a lexus sc300 and i have a stereo issue. i dont have any power coming to the stereo. i though that it is because of a fuse problem, but i check all the fuse and all the fuses are good. so i went to go buy a amp from the dealer and i change it and that not the issue.. so someone please HELP ....
Have you checked the wiring on your ((STEREO))? If you were unlucky like me, someone mightn't put a deck/in-dash in before hand and did a BAD install job with the stock harness which you're not supposed to splice off/cut.
If it is that you're going to need a reverse-harness, Harness that way you can clean up the factory worse and still have a harness to plug into the radio or receiver you get.
